×Hi ,
updated the Text Field (single line) using script runner , the script runner has updated the CustomFiled , but not able to query using JQL with updated customField , it is not displaying any rows if updated custom Field used in JQL , but the value has been updated , updated column is Test_Email with Value 1001
Tried with Text & number in updation
def tgtField = customFieldManager.getCustomFieldObjects(myIssue).find {it.name == "Test_Email"}
def changeHolder = new DefaultIssueChangeHolder();
tgtField.updateValue(null, myIssue, new ModifiedValue(issue.getCustomFieldValue(tgtField), "1001"),changeHolder);
Output from Database
mysql> select * from customfieldvalue where issue=(select id from jiraissue where issuenum='2079') and CUSTOMFIELD=11300;
| ID | ISSUE | CUSTOMFIELD | PARENTKEY | STRINGVALUE | NUMBERVALUE | TEXTVALUE | DATEVALUE | VALUETYPE |
| 41245 | 15500 | 11300 | NULL | 1001 | NULL | NULL | NULL | NULL |
1 row in set (0.00 sec)
Screen Shot After updating using the Script runner
You should use IssueService to update which will do the proper re-indexing for you after the update: https://docs.atlassian.com/jira/latest/com/atlassian/jira/bc/issue/IssueService.html#update-com.atlassian.jira.user.ApplicationUser-com.atlassian.jira.bc.issue.IssueService.UpdateValidationResult-
Here is some example code of how to use it in your script:
import com.atlassian.jira.component.ComponentAccessor def user = ComponentAccessor.jiraAuthenticationContext.user.directoryUser def issueManager = ComponentAccessor.issueManager def issueService = ComponentAccessor.issueService def issue = issueManager.getIssueObject("KEY") def issueInputParameters = issueService.newIssueInputParameters() issueInputParameters.setDescription("Updated description") def validationResult = issueService.validateUpdate(user, issue.id, issueInputParameters) if (validationResult.isValid()) { issueService.update(user, validationResult) log.info("Updated issue") } else { log.info("Invalid update") log.info(validationResult.errorCollection) }
@Gabrielle Bautista [ACP-JA] @Adam Markham [Adaptavist]
Thanks for support
After reindexing it's works fine ,
Added indexManager.reIndex(issue); in the code to Reindex the field
