Not able to view manage add on section in admin settings.. can you guide me exactly..how to install jira editor software using admin. i have checked and granted admin, site access to me. But still not able to view manage add on section in admin settings. can you please help ? am using jira trial software..
Ramakrishnan,
You must Administer Jira Global Permissions.
From your main JIRA Screen clic JIRA Settings -> Apps:
https://screencast.com/t/sWHIjYT3
Then Find new apps.
Also when logged in as a JIRA administrator you can hit the g key twice 'gg' and it will pop up with a shortcut list, where you can type in add-on:
https://screencast.com/t/IrET0vPqw
If you can't get to either of these screens, you need to re-check your permissions.
-Josh Loe
Thanks Josh for the quick reply.. can find new apps through jira settings.. however shortcut didn't work for me..not sure why...
However i can't find jeditor software in app search..please help. Thanks
Ramakrishnan,
Are you talking about this add-on: JEditor - Rich Text Editor for Jira.
If so, it is only available for JIRA Server, not JIRA Cloud.
If you have server, just go to the link from above and download.
