Not configuring home directory correctly
Brighid Lynch
June 2, 2014
I keep getting the following error message when trying to run Jira from my Mac.
Configured jira.home '/Users/blynch/JIRA' must not be a parent directory of the webapp servlet path '/Users/blynch/JIRA/atlassian-jira-6.2.6-standalone/atlassian-jira'
Any idea why this might be happening??
Nic Brough -Adaptavist-
June 2, 2014
Jira needs an installation directory and a home data directory.
You must NOT put the installation directory anywhere within the home data directory, it breaks things. Create separated out directories for them (e..g /users/blynch/jira/Home and /users/blynch/jira/install )
Julian
June 2, 2014
Heya Brighid,
Could you try to create a separate folder for JIRA home? For example, /Users/blynch/JIRA/Home and set the JIRA home in that Home folder.
This is due to JIRA installation folder(atlassian-jira-6.2.6-standalone) will be inside the JIRA home folder.
Hope this helps.
