Hi, i want to get a notification on my slack private channel whenever a issue is created in my Jira Project.
Also want to filter out(not want these) those issues which are created through automation.
If you are using Automation for Jira, you can easily create the triggers you want including the specific tickets you want to track and then setup an action which will send a message to Slack (to your user or a channel).
This requires to configure an incoming webhook first, which is doable by a Slack admin.
See more here: https://support.atlassian.com/jira-core-cloud/docs/use-automation-with-slack/
