OnDemand JIRA maximum issues
Satish Kumar Jayaram
We need to find a sizing factor in JIRA OnDemand version. Following is our requirement. Could you please confirm whether JIRA OnDemand will support the follwing requirements. If not then could you please suggest what kind of hardware we may required for Download version?
Users : 200+
Regular users : 100+
Numer of issues per day = 3000+ issues per day.
Number of projects = 200+
Number of custom fields =50+
Number of Workflow = 5(max)
Satish Kumar
Jorge Dias May 27, 2014
Hello Community,
Let me add these two documentations that can help to understand better the Ondemand Platform.
https://confluence.atlassian.com/display/AOD/Atlassian+OnDemand+FAQ
https://confluence.atlassian.com/display/AOD/Restricted+Functions+in+Atlassian+OnDemand
Hope that helps.
Jorge Dias
LucasA
May 27, 2014
Hi Satish,
Note that there’s no golden rule to perform this sizing since OnDemand platform have some particularities over the standalone applications.
None of your given parameters really matters, since the performance will depends more about the number of simultaneous access and what kind of performed tasks. Large number of API requests may impact instance’s overall performance too.
Note that OnDemand have a storage limitation of 25GB, so if you have more than this now, maybe you’ll need to remove some data before proceed with the migration.
I believe that you may proceed raising a support request at https://support.atlassian.com.
There our Product Advocates team may help you to perform a better sizing.
Lucas Lima
