I meet a problem that GUI display Oops 500 message.
I capture the log (logs/atlassian-jira.log) display below:
Could you help me how to solve it?
2018-03-01 19:14:15,790 http-nio-8080-exec-1 ERROR - [o.a.c.c.C.[.[localhost].[/].[action]] Servlet.service() for servlet action threw exception
java.lang.NoClassDefFoundError: Could not initialize class webwork.dispatcher.GenericDispatcher
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.prepareDispatcher(JiraWebworkActionDispatcher.java:196)
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:133)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165)
... 86 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
The issue happened on reboot JIRA.
The JIRA version is JIRA v7.4.3.
No help to restart.
Use JRASERVER 62486 can be solved this issue. Ths.
Hi hsieh,
There is an older bug that was fixed in 7.3.9 that may match what you're seeing. You can find it at JRASERVER - 62486: Accessing a non-existent url in JIRA during startup will break access to the instance until a restart is performed.
Let me know if that helps. If not please provide the answers to the above questions and we'll go from there.
Branden
