Order By clause Jira filter
Corinna Führing
Hello, does anybody know where i can finde the order by clause in the JIRA Filter ?
Phill Fox
Hi Corinna
If you look at the filter in the search for issues and switch to Advanced view you will then see if there is an ORDER BY clause present if not you can simply add ORDER BY assignee and save the filter.
Corinna Führing
project = DAIENTRY ORDER BY    what is wrong in that syntax.....
Phill Fox
Do you have a field after the ORDER BY clause? eg project = DAIENTRY ORDER BY assignee
Corinna Führing
nice thanks now it works !
Phill Fox
Hi Corinna Glad it worked for you. Please remember to accept my answer so that anyone else searching for the same problem will find this page. Phill
Corinna Führing
