Order of nested post-function executions/creations
Steven Mustari
December 31, 2019
I have a post-function on issue A that creates issue B and conditionally issue B may or may not create create issue C. All of these issues are on different workflows.(don't)
What is the order in which these post-functions are executed?
My primary point of discovery here is to determine when exactly the first execution stores and re-indexes, as within creation B or C, I would like to come back and potentially clear a field on A or B.
Steven
Derek Fields (RightStar)
Post-functions fire in the order in which they are called. Issue A creates Issue B. The creation of issue B may create Issue C. It will happen in that order.
I think your real question is the order of the reindexing? I am not sure, but it may be indeterminate. If the plugin that creates the new issue spawns a new thread to create the new issue and run its Create post-functions, then you may not be able to reliably count on the order in which the threads complete.
If it all occurs in a single thread, then I would expect all of C's Create post-functions to complete before B continues and all of B's post-functions to complete before A continues.
Steven Mustari
January 21, 2020
Thank you Derek, I think the reindexing part is what was concerning, I didn't think about each of these processes opening on a different thread, therefore unreliable order, which at times explains some unexpected behavior.
Steven
