Ordering - Work Flow Action in Actions
Pavol Lackovič September 3, 2012
Hello, is there a way how to setup WorkFlow Action order in Action menu in Filter Result Gadget?
We used Step properties „opsbar-sequence“, it work perfecty in Detail Issues screen, but this setup is ignored on Dashboard Gadgeds.
Thank you
EL June 1, 2015
That's a good question...I would like to achieve the same thing.
Anyone with a idea ?
