Original Estimate field not visible in Create Issue
KP11
April 12, 2013
I am trying to add Original Estimate field in the Create Issue screen.
I do not see it in default screen to add. How do we make it visible?
8 votes
Nic Brough -Adaptavist-
April 12, 2013
Look for "time tracking" rather than "original estimate" in the list of fields to add to the screen - try that instead. (The estimate and time tracking fields are actually all one field, displayed differently)
KP11
April 12, 2013
Does Legacy Mode make a difference?
KP11
April 12, 2013
Is there one screen that defaults for all Create Issue?
I do not see a default screen for create issue
April 12, 2013
Depends on how you've set it all up.
See https://confluence.atlassian.com/display/JIRA/Associating+a+Screen+with+an+Issue+Operation
(I'm not sure what you mean by legacy mode - there's a couple of things it might refer to, but they're minor and have nothing to do with screens, just the way some data is handled)
KP11
April 12, 2013
I edited the Default Screen and do not see Time Tracking in the pulldown.
https://jira.ibaset.com/secure/admin/ConfigureFieldScreen.jspa?id=1
Time Tracking does not show in the pulldown for the selection
KP11
April 12, 2013
Yes i found it. They were using custom screens so i had to edit in there
April 12, 2013
Have you got Timetracking enabled in the global configuration? If it's off, it won't let you see the field at all.
KP11
April 18, 2013
Done
KP11
April 18, 2013
Answered by Nic
Ramiro Pointis
April 18, 2013
Mark his answer as correct then ;)
