Parameter (accountId) does not match required pattern
Sylvie R_ October 28, 2024
I am retrieving a list of users via the v1/orgs/{org_id}/users/search API.
From that list I extract the accountId and with that call the API
"https://api.atlassian.com/users/"+accountId+")}/manage/profile".
And I get the following answer:
{ "context": { "message": "Request validation failed: Parameter (accountId) does not match required pattern: ^[a-zA-Z0-9_|:-]{1,128}$", "paramName": "accountId", "path": "paths->/users/{accountId}/manage/profile->get->parameters->0" }, "errorDetail": { "message": "Request validation failed: Parameter (accountId) does not match required pattern: ^[a-zA-Z0-9_|:-]{1,128}$", "paramName": "accountId", "path": "paths->/users/{accountId}/manage/profile->get->parameters->0" }, "errorKey": "bad-request-format", "key": "badRequestFormat" }
How can the accountId retrieved via API not be correct?
Evgenii
Hi, @Sylvie R_
Welcome to Atlassian Community
Looking at your url, I think, it's the reason. You included ")} in it.
This is, for example, my script in python, which I use to work with users data
def get_profile(account_id):
url = f"https://api.atlassian.com/users/{account_id}/manage/profile"
response = requests.get(url, headers=admin_headers)
if response.status_code == 200:
return response.json()
else:
pass
Also pay attention, that you need to check, that user "accountType" == "atlassian".
Sylvie R_ October 29, 2024
That was it, I feel a bit stupid not to have spotted it.
Like Evgenii likes this
