Parse JIRA issue key in Bamboo from SVN commits
Michael Wang June 12, 2013
Hey there, I need some help here, I have a plan with two stages in my bamoo server.
My commits is in the format of "JIRA-ISSUE-KEY message"
I have a trigger detecting code changes in the first stage
So I wonder if there's a way to parse the JIRA-ISSUE-KEY as a vairable and pass to the second stage
Michaell W.
Sultan Maiyaki
June 15, 2013
Hi Michael,
This is actually not exposed as a build variable in Bamboo and it seems this will not be implemented because of added complexities if a single build comes with hundreds or thousand of commits as stated in the improvement request https://jira.atlassian.com/browse/BAM-11958
Two things you could do as thus:
1. Write a script task to get the commit messages from the repository and then find a way to extract the keys
2. Write a script task that will do some REST API calls to retrieve the commit messages
Sultan
Michael Wang June 19, 2013
Hey Sultan, thx a lot for the suggestion, I haven't actually tried yet, but seems like doable, will try it out and post the result later.
Michael Wang June 13, 2013
Anyone can help?
