×I need to parse comma separated input (multiple usernames) [from a text (custom) field] and then for each user check their validity against LDAP. Has anyone done something similar in past?
I am looking for code which can be used to parse/split input values delimited by comma
If you can, you should script the solution or probably contact an Atlassian partner who can do custom development. The latter being the fastest way to get your solution.
