Permission scheme per project
Manoj Nambiar November 28, 2018
Wanted to check if there is a limit on the permission scheme for the entire JIRA instance.Can we have a permission scheme per project.Will it impact the performance if we have one permission scheme per project.
Johan Soetens _Dumblefy_
November 28, 2018
The number of schemes in your instance is one of the factors that affect performance, try to re-use schemes and workflows.
Joe Pitt
It can become a nightmare when trying to figure out who can do what. By using project roles I have one permission scheme for all projects. I document the permissions so project admins can decide what project roles they want to use.
Tom Lister
Hi @Manoj Nambiar
You can certainly have one permission scheme per project. That is how it is intended to work.
My only advice for schemes is avoid using the default schemes where possible as they may change.
