I'm looking for a solution to pin a comment and to pin an attachment in a jira issue. The issue itself have many different comments and attachments.
Any ideas?
Thanks!
Best regards,
David
I have developed this server app to pin comments: https://marketplace.atlassian.com/apps/1223490/pin-your-comments?hosting=server&tab=overview
Hi @David Choi
Do you want to pin important comments and attachments on top, to make it the most visible comment? I do not know of any add-ons fulfilling this requirement.
There is at least a Suggestion open in Atlassian's Jira for pinning comments: https://jira.atlassian.com/browse/JRASERVER-60438
Follow and vote for it.
But currently I this is not part of Jira.
Hi Niklas,
yes, I'm exactly looking for this kind of feature or at least an add-on.
Thank you for sharing the link for the new feature suggestion, now this answer my question.
Hi @David Choi , like you we've also wanted a way to pin a comment on top of a Jira Issue. It's especially helpful when there are long conversations, and you want to record and highlight the details that are the most relevant.
We created a Jira Cloud app that allows you to pin one or more comments to the top of your Issue. The app records the comment that was pinned, when the comment was pinned, and who it was pinned by. You can make it easy to find the most pertinent information at a glance:
The app is called Pinned Comments, and you can find it here: https://marketplace.atlassian.com/1234011
Try the app out, and let us know what you think. Thanks!
