×since you have scriptrunner installed you can use
issuefunction in linkedissuesof("issuetype = epic and fixversion =ABC_123")
the second one should be optional linkedIssuesOf(Subquery, [link name]) see :https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+JQL+Functions#ScriptedJQLFunctions-linkedIssuesOf(Subquery,[linkname])
The second one is optional as of some version... either update your SR, or you need to specify the link name.
"is Epic of" or "has Epic" for the second argument, can't remember which.
Would this suffice?
fixVersion = ABC_123 and "Epic Link" is not EMPTY
