×Hi all,
I installed the plugin Behaviours-jira-0.4.6.jar in Jira 4.4.3 and i am having problem with read only fields in IE7.
When i tried edit the issue in Firefox the fields that i don t have permission access are showed as read only in firefox. It s perfect.
But in IE these fields are showed as writable . It s wrong. I would like that these fields were only read only idem firefox
Please do you know other way of the do this plugin works in IE7.
Note: The solution of the turn of the compatibility mode from IE was not accept here in my company .Is there any other way ?
Thanks in Advance
Best Regards
Fabio
Fabio,
There is quite a lot of info on compatibility mode here: https://studio.plugins.atlassian.com/wiki/display/JBHV/JIRA+Behaviours+Plugin?focusedCommentId=65668197#comment-65668197 and a bug or two in the project.
Not trying to be unhelpful, but from my side, I don't intend to try to get it working with IE in compatibility mode. As far as I can tell, lots of other things are also broken in jira when in compat mode.
Also I don't and can't test in IE7, the testing matrix is too big already.
jamie
Hi Jamie
It will be possible Jira turn off automatically the compatibily with IE?
Best Regards
Fabio
Hi Fabio,
I don't know, there is a lot of debate about this. I don't understand the rules it uses to go into compatibility mode. Maybe you can change whatever makes it choose compat mode, eg the hostname, or look at setting a meta header. Again, check jira.atlassian.com and google, I don't know much about this.
cheers, jamie
