Plugin for Test Management in Jira OnDemand
Praneel Redlapalle November 20, 2014
In my previous project, we used a Test Management plugin in JIRA called Zephyr. It was pretty collabarative. But in my current project, we are using the OnDemand version of JIRA & Zephyr is not yet suppported. I explored various other plugins like Zest & Behave Pro but none are as collabartive with JIRA as Zephyr is. Any suggestions?
Praneel Redlapalle December 16, 2014
Hi Clarissa, I tried Standalone version of Zephyr with JIRA Connector. The experience was quite bad. The inline version of Zephyr was 10X better.
Thanks for the response.
Best,
Praneel
cgauterio
November 26, 2014
Hi Praneel,
I believe you can use JIRA itself test management. Please check Using JIRA for Test Management for more details about it. In addition to that, you can also try using the add-on that is available for OnDemand Zephyr Enterprise Connector for JIRA
Hope this helps.
Clarissa.
