×I haven't found a way to export screenshots using Document Generator. It seems this only exports the image metadata
Is there a way to gather all those screenshots and package it into a .zip file?
HI @Ryan Nguyen ,
Doesn't seem there's a way based on similar post in this regard:
You may want to connect directly to the xray support to see if they have new support, feature, or tool that extends this capability.
-Ben
