Post Security Level on Issues
B. Normann P. Nielsen
December 14, 2011
We have several Issues without Security Level set, most of them closed. This enables jira-users to see some they should not have access to...
Is there a way to "reapply" these, I would prefer not the "Edit, set field, save" method.....
An SQL to fix is would be supernice :-)
December 18, 2011
THis will do it
{code}
mysql> select * from schemeissuesecuritylevels;
| ID    | NAME       | DESCRIPTION | SCHEME |
| 10000 | OnlySeeOwn |             |  10010 |
1 row in set (0.00 sec)
mysql>
update jiraissue set SECURITY=10000 where project=10040 and SECURITY IS NULL;
update jiraissue set SECURITY=10000 where project=10130 and SECURITY IS NULL;
{code}
December 18, 2011
We need to reindex afterwards, otherwise views will stille show the issues to the user
Jobin Kuruvilla [Adaptavist]
December 14, 2011
Maybe find the appropriate level from schemeissuesecuritylevels table and set the id into the security field in jiraissue table! I haven't tried it before, so pls test.
