Power Automate Get List Of Issues Not working
Mark Porter
March 24, 2025
I'm trying to export a list of issues for a specific project to SP but the online documentation for this connector does not seem to detail the correct string format to be able to do this.
If i use the base URL of the Jira instance it returns zero issues, if i try to use a JQL query int he string it tells me i cannot use / in a jql query even when there is no / in the query.
Can anyone help with the correct format for the Jira instance parameter for the Get list of issues component please?
David Nickell
March 24, 2025
hope this helps.... I don't use a connector, but here are some related REST API calls.  The instance in a rest call looks like this:
https://splitdimedata.atlassian.net/rest/api/3/component/10011
Using the jira.atlassian data for an example -- here are some REST calls. (Enterprise uses version 2 of some of the same REST calls as cloud -- which is version 3)
Mark Porter
March 24, 2025
Thanks David, all these rest calls work for me when i use them directly in the browser but they all fail when i try to use them with the OOB jira connector. I am pretty sure they would work if i used the HTTP connector but our company doesn't allow the use of that one
ENTERPRISE
