Hi
I am using the Power BI Connector to import Jira data to Power BI.
For one JQL string I have several tables to choose from in Power BI when importing the data.
One of these tables is a "History" table containing the history for the "Remaining Time" variable from Jira. Another table is called "Issue" which contains the current "Remaining Time" variable from Jira.
I am experiencing some problems as there are some keys in the "Issue" table with remaining time. However, these do not appear when I import the "History" table.
Howcome same keys are not present in both tables? The JQL string is the same.
Best regards
Hello Rasmus @Rasmus Søndergaard Knudsen ,
If you use Power BI Connector for Jira, could you please create a support request at our Help Desk and share some additional details such as JQL you use and the results you get in Power BI (screenshots)? We'll help you to troubleshoot the issue asap.
Luba
