Power BI Created vs. Resolved Chart
Blair Zagata
August 20, 2025
How does the built-in Atlassian created vs. resolved gadget work, it shows that we resolve more issues then are created a day,  Screenshot 2025-08-20 141936.png
however in Jira custom reports and Power BI is shows that we never resolve more tickets then are created, Screenshot 2025-08-20 142317.png I have gotten it to work in Power BI but now have the issue of date slicers breaking the graph, this is what it should look like, Screenshot 2025-08-20 142558.png
and this is what it looks loke with a date slicer, Screenshot 2025-08-20 142714.png
how do I set up a created vs resolved graph in Power BI that works with date slicers and shows the true count of tickets created and resolved in a day (like the gadget), I have attached an example Power BI report so you can see what I am doing, I am querying the database directly, and would like to not use any plugins
Jira date table and Created vs closed table Help.pbix
jira data.xlsx
Danut M _StonikByte_
Hi @Blair Zagata,
Welcome to the Atlassian Commnity.
In the Atlassian documentation (see https://support.atlassian.com/jira-cloud-administration/docs/use-dashboard-gadgets/) you can see that the gadget "displays a difference chart of the work items created vs resolved over a given period".
So, for a given day/week, it shows the number of issues reported on that day/week plus the number of issues resolved on that day/week, which may include issues reported in the past, not necessarily just issues reported on that week! Therefore, it is possible that there are more issues resolved than reported for a day/week.
Would you expect a cumulative chart for reported vs resolved? Something like this?
I'm not familiar with Power BI, but, if you consider using other app, you can get a chart like this by using our Great Gadgets app. See https://community.atlassian.com/forums/App-Central-articles/A-powerful-Reported-vs-Done-chart-for-Jira-dashboards/ba-p/2610902?utm_source=atlcomm&utm_medium=email&utm_campaign=kudos_article&utm_content=topic
Danut.
Blair Zagata
August 21, 2025
@Danut M _StonikByte_  Thank you for the reply, the issue is that in Power BI it wont show more issues resolved then reported when it should, it is not showing the same data as the default gadget, if you know what database table to use that would be helpful (I think its the jiraissue table) I am most likely pulling the wrong data or have it misconfigure, unfortunately I don't think your Great Gadgets app will work as we are using Power BI so we can have reports not form Jira in the same place
