Pre-Select Issue Templates on my Jira Project
Sinan Gürcan
October 10, 2024
Hello everybody,
We've recently migrated to Jira Cloud, and I am missing an option I've been using desperately, so maybe you can help me how to reactivate it.
In my project, I want to utilise different templates per issue types. Meaning: When I hit 'Create' in the project page, I want the description field to be populated based on the issue type I've selected (Epic / Story / Bug / etc.).
So far I am struggling to find how - thanks for your help!
2 accepted
Marc - Devoteam
October 10, 2024
Hi @Sinan Gürcan
Welcome.
In you previous server/DC instance you probably had a 3rd part app or custom development for this.
In Cloud you will need a 3rd party app for this, see options here
Kate Pawlak _Appsvio_
There is no native solution for templates. As Marc said, you need an app for it. I can recommend you our app Issue Templates Agent which works exactly how you expect: you click Create button and on the Create issue dialog a predefined template is applied (automatically or you can select it from Template field).
