Pre-filled values in sub-tasks when clicking 'Create another issue'
Spasimira Genova
Hi community,
Is there a workaround for values to not be pre-populated when sub-tasks are created subsequently?
I'm referring to when creating a new sub-task, the 'Create another issues' button at the bottom of the screen is marked down.
Many thanks
2 accepted
Bill Sheboy
August 23, 2024
Hi @Spasimira Genova
There is an open defect for this symptom happening intermittently.  You may vote for / watch it to see any progress: https://jira.atlassian.com/browse/JRACLOUD-81380
Reading through the comments on that defect, you can see the behavior and specific fields not cleared is inconsistent.
Shreeja J
August 23, 2024
Hello @Spasimira Genova ,
Currently, Jira doesn’t have a built-in feature to stop fields from being pre-filled when using the 'Create another issue' option for sub-tasks. This button uses the values from the last created issue to pre-fill the fields for the new one.
As a workaround, you might consider:
  • Clearing Fields Manually: After clicking 'Create another issue,' you can manually clear or adjust the pre-filled fields before saving the new sub-task.
  • Using Automation or Add-ons: For more advanced customization, you could explore Jira add-ons or automation rules that may help clear specific fields when creating new issues.
Let me know if you need more details!
Shreeja J.
Spasimira Genova
Hi @Shreeja J
Thank you so much for confirming, I thought this might be the case.
Best wishes,
Spasimira
