Prevent JIRA System fields from being copied to SubTasks from it's Parent tasks
Mariselvam Lakshmanasamy February 7, 2014
When creating sub tasks, it just copying the basic system fields (such as Component(s), Priority, FixVersions,etc..) from it's parent task automatically.
But it should NOT copy certain fields(say FixVersions). The FixVersions field should only be updated on the subtask when it is resolved. How can this be achieved? Do anyone have ideas???
I'm running version 5.0.7
Thanks in Advance!!
Mariselvam Lakshmanasamy February 18, 2014
It looks by default JIRA version 5.0.7 inherits basic system fields to sub-task from it's parent task bypassing all the restrictions/functions we put on workflow.
For example, if we add a function on workflow(at the point of creating the sub-task transition) to clear the FixVersions field, JIRA system bypasses this workflow function when creating sub-tasks.
It looks Atlassian has fixed this problem on their release 6.*
Jobin Kuruvilla [Adaptavist]
February 7, 2014
You must have a script or customization that copies these fields because JIRA doesn't do that by default. Find that customization and see if you can exclude the fixVersion field.
Nic Brough -Adaptavist-
February 7, 2014
Actually, yes, it does. I just tried it in 6.1. If the user leaves either version field or the components unfilled, it inherits the values from the parent
February 7, 2014
I don't see it in 6.1.1. Tried creating a subtask on a Task which had fixVersion filled in.
February 7, 2014
Hmm. The Jira I tried it with is pretty much empty. One project, 6 issues, two custom fields and using the default workflow.
Maybe it's the Agile or Service Desk plugins doing this...
February 8, 2014
I see. I don't have Service Desk but has JIRA Agile. Is that the one? ;)
Mahesh S
June 12, 2016
Yes! This feature comes via JIRA Agile plugin.
