Prevent Project Administrators to edit the project role members
Olivier Bourquin December 11, 2011
We have a very straight and strong permissions schemes defined for our projects in JIRA,
but persons with the Administer Project are able to change the Peoples in their projects.
So any project admin can add members to the developers role, for example.
Is there a way to prevent that they can administer their persons?
Olivier
Nic Brough -Adaptavist-
December 11, 2011
Not natively, and I've not seen a plugin that can control it either. You'll have to trust your project admins.
Although, there is a plugin that lets you audit what they do in project admin - at least then you could identify and tell off the ones who do bad things.
Olivier Bourquin December 12, 2011
I've voted to https://jira.atlassian.com/browse/JRA-11884, maybe sometime they will implement that? Well, the issue is open since 2007 :-(
