Hi you all
I´m very new of the tool Jira and the Add On Script Runner.
I would like to know if someone passes through this same issue that I have and could please enlight me on this
I have this specific situation:
For each Story that we will develop we have a specific Issue Types for each phase of the Story, for example:
Story X (Related to Issue Type below)
----- Issue Type Development A (Related to Story X)
----- Issue Type Tests B (Related to Story X)
But on Workflow of the status "To Do" -> "In Progress" from Issue Tests (B), I need validate if the Issue Development (A) is in the status "Done",
if don´t I need to block this transition.
We have the Script Runner Plugin in my company, so I think it could be resolved with the Script Runner AddOn
Ao I add Validator in the workflow of Issue Type Tests, in a transition "To Do" -> "In Progress" (Add Validator To Transition)
Select Script Validator [ScriptRunner], and select Simple scripted validator
Here I will input a validation that could be like this:
Declare a variable
Boolean passesCondition = true
1 - Get the issue Story X related to the actual issue that is transiting (Issue Type Tests B);
2 - With the Issue Story in hand I need to get the issue type Development A (related to the same Story X);
3 - With the Issue Type Development A I need to check if the Status is "Done" (.getStatus().getName().contains("Done"))
4 - If the status of Issue Type Development is "Done" I will return passesCondition, otherwise If this is in another status (like "In Progress"), I put passesCondition = false and return passesCondition
Anyone could give me a help on this, please?
Hi folks,
I'm with a similar issue, it's being hard to deal with Script Runner.
Could anyone give us a hand?
