I had integrated JIRA and confluence by app, I follow step by http://www.jennywatson.net/2011/03/30/integrating-confluence-and-jira/
I select recent jira issue or add isue well, but search issue in confluence error.
Error message is : "Recieved the following HTTP error code from the server:0'".
PS: step
I’ve already created an issue in JIRA, so now I want to pull that issue into my Confluence page.
I believe that the BaseURL could be wrong, could you please go to Confluence and Browse > Confluence Admin > General Configuration and check if the BaseURL matches the URL that you're trying to access? Also try to find the BaseURL in JIRA side, making the same changes, BaseURL matching the URL.
If you're using proxy, maybe JIRA cannot reach Confluence. For that I would suggest to bypass the proxy and try again.
I hope this helps.
WZ
I am sure the BaseURL is right.
Confluence and JIRA are deployed in a same server.
Try to turn on the oauth authentication in both JIRA and Confluence.
In JIRA go to Application Links click Edit -> Outgoing Authentication -> Oauth and click Enable.
The same steps for Incoming Authentication in JIRA.
Also you should do the same in Confluence.
I have this same problem.
I work on JIRA v5.2.4, Confluence v5.0.1.
BaseURL is correct.
Jira and Confluence works on the same server.
Same issue here too, with JIRA 5.2.4 and Confluence 4.3.7.
I've double checked the base URL, as well as deleting and re-adding the application links. Other sources indicate the specific versions of the AppLink Plugin might have issues, and upgrading to Confluence 5 may potentially fix it... haven't seen anyone confirm it yet however.
Firstly, which version of Confluence and JIRA that you're trying to integrate?
Secondly, I would recommend you to refer to our official documentation at the following link.
https://confluence.atlassian.com/display/DOC/Integrating+JIRA+and+Confluence
Hope this helps
