I can’t set the sprint date correctly
when you select a date in the calendar, 0020 is set. I put the number 20.04, jira sets the 16 number
if you set the date manually, swears at a long sprint
The problem arises when choosing weekly sprints.
after editing the date, the sprint starts with the year 0020
If you type the dates manually, then everything works fine
The system time is correct
