Hi everyone!
Im migrating from windows server and sql server (now A) to ubuntu server and postgresql (now B).
Im trying to import a project from A to B and i cant, they are both in the same version of course, but i cant solve the mistake that says in Spanish
"El campo personalizado 'Estado de épica' requiere la opción 'Listo' para la importación pero no existe en la instancia actual de Jira."
When i tried to fix that, Jira says that is blocked cause of it is a system custom field.
How can i solve that? I need to import that project to keep using jira!
Done,, i insert a line in table customfieldoptions
Hi @luciano_carlomagno_neuralsoft_com ,
it would be easier for you to import the full instance A into the new instance B. You can do that by doing a XML backup in Jira and importing it, as described in this documentation : https://confluence.atlassian.com/adminjiraserver/switching-databases-938846867.html
Let me know if this helps,
--Alexis
