Problem in Layout Card
Camila Rocha
July 12, 2023
People,
I have a board on JIRA taht it is a conection of several boards. And I want to put some fields in the layout card. Now, I can´t anymore. Are there more people with the same problema?
Sanjog Sigdel
@Camila Rocha
Can you please elaborate with screenshot and context. From what I understand, you need to make sure that the fileds you want to display in your layout falls under the project where you want to create the board. To do so
  1. Go to Settings
  2. Issues
  3. Custom Fields
  4. Edit the context
  5. Make it available in Global context for all projets.
Hope it helps
