I'm new to Script Runner plugin.
The problem we are facing is, we have added the script to send a custom email which we got in the below link.
http://stackoverflow.com/questions/15272864/jira-for-bug-tracking-and-customer-support
I'm getting exception when running the script. Please help me out in resolving the exception.
Thanks and Regards,
Madhanaa S R
as @Chrishtian told without log, no one will help you
have you gone through the following doc
https://jamieechlin.atlassian.net/wiki/display/GRV/Built-In+Scripts#Built-InScripts-Sendacustomemail
Yes. I have gone through the document. We actually want to send emails to external users. So we went for the script in the link mentioned above.
We need the exception, not the task...
What Christian said. And see https://jamieechlin.atlassian.net/wiki/display/GRV/Getting%20Help#GettingHelp-Supportrequests for exactly what you need to provide.
javax.script.ScriptException: javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: issue for class: Script31
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:117)
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:216)
at com.onresolve.jira.groovy.GroovyRunner.runFile(GroovyRunner.java:110)
at com.onresolve.jira.groovy.GroovyRunner.run(GroovyRunner.java:61)
at com.onresolve.jira.groovy.GroovyRunner.doExecute(GroovyRunner.java:244)
at webwork.action.ActionSupport.execute(ActionSupport.java:165).....
This is in the code you are providing - can you post a screenshot of the whole configuration page
Ok. Is there any way to get the issue key when an issue is created? If so please share me the code..
I'm getting error when we use issue.getKey(). And the error is
The problem is I don't know where you are using this, which is why I'm requesting the screenshot.
Hey,
even if I can't help you others might... but I doubt that they will be able to help if you don't provide details about the exception (log excerpt)
Cheers
Christian
