Problem installing JIRA Suite plugin
Daryl Coston February 11, 2013
I installed the JIRA Suite Utilities 1.3.4 plugin on two servers and I'm getting the following error when I attempt to enable the plugin. Please help with this issue.
This plugin failed to enable. Your license may be invalid. Please refer to the logs for more information
Daryl Coston February 13, 2013
Vishnu, unfortunately I can not send you our log information due to our security policy. I have looked at the logs and I'm seeing to some information like DelegatingPluginFilter.java:74, SecurityFilter.java:234, ApplicationFilterChain.java:235. I'm not sure what this means but we are currently running java 1.6.0_31
Vishnukumar Vasudevan
Do you see anything helpful in the logs ?
Faisal
February 12, 2013
Good morning,
I did a quick check on the JIRA Suite Utilities plugin details in the Atlassian Marketplace, and I see that the plugin version 1.3.4 is made compatible with JIRA 5.1 and above. Since this is the case, may I know what is the current JIRA version that you are currently running on? If you are running on JIRA prior to 5.1, then can you please downgrade the plugin version and see if it helps?
Cheers.
Ahmad we are running JIRA 5.1.3
