×I have both JIRA (5.2.5) and Stash (2.1.2) running behind Apache2 on the same physical machine. Both are accessible via their respective base URLs (over https). I'm in the process of setting up Stash via the Stash Installer web interface (database connection is fine), and I'm at the JIRA integration step. I put in the information it asks for, and I get an error message about my base URL for JIRA: "There doesn't seem to be a running JIRA server (version 4.3 or later) at this URL."
My best guess is that it has something to do with my self-signed SSL certificate, but I'm not sure. Does anyone have any insight into what might be going on here? Thanks.
can you please check if both apps are using the same JAVA binary?
i.e.
ps axf|grep jira ps axf|grep stash
by default Jira uses its own JRE
i think stash choses the JAVA from your hosts environment
in that case the cert file needs to be imported in this keychain as well.
OR
you configure boths apps (JIRA & Stash) to use the same JAVA <- thats what i preferred.
Thanks for your input. Running the suggested ps and grep commands did show JIRA and Stash use different JREs; JIRA using its own, and stash using the $JAVA_HOME JRE. I like your suggestion of both of them using the same; I'm leaning torwards both of them using the one in JIRA's installation directory. How do I configure Stash to use that JRE? Thanks again.
Thanks for the suggestion; I tried setting JAVA_HOME in stash/bin/setenv.sh, but after restarting Stash (and the machine) it didn't seem to pick up the change. I'd prefer not to change the system JAVA_HOME.
I looked in the JIRA setenv.sh, and it had a commented out JAVA_HOME assignment, so I figured adding the JAVA_HOME to Stash's setenv.sh would work (like you suggested), but no go.
I'm going to look around some more at how to set Stash's JAVA_HOME. Thanks again.
my recommendation would be to install java (oracle) and update your systems env by adding
export JAVA_HOME="/usr/java/latest"
then make jira use this java as well by making this change to the permgen.sh
#JAVA_HOME="/opt/atlassian/jira/jre/"; export JAVA_HOME JAVA_HOME="/usr/java/latest"; export JAVA_HOME
now you just need to import the certfile into $JAVA_HOME/lib/security/cacerts and you should be fine
I ended up asking the specific question of whether it was possible to configure Stash to use a Java that's not necessarily JAVA_HOME or first found in PATH.
https://answers.atlassian.com/questions/137702/how-do-i-configure-stash-to-use-a-specific-java
My impression is that Stash must use the Java in JAVA_HOME or in PATH.
You can set JAVA_HOME and PATH in bin/setenv.sh and it be local to the Stash installation (link in previous comment).
So now I have both JIRA and Stash using the same Java, like you recommended. Thanks again.
And I had tried that when you suggested it. Perhaps it's also necessary to include the value in JAVA_HOME in PATH.
JAVA_HOME="$JIRA_HOME/jre" PATH=$JAVA_HOME/bin:$PATH
I added my public self-signed ssl certificate to my JIRA JRE keystore as instructed from my previous comment (and restarted the machine), but I still get the same error at the JIRA integration step of configuring Stash. Any ideas?
In case someone else comes across this, I'm looking at this as a possible solution: https://confluence.atlassian.com/display/JIRA/Connecting+to+SSL+services
