Problem linking GitHub and JIRA
Roustem Karimov
June 16, 2013
I keep getting the "Unable to link selected repository. Do you have administrator permissions on the {GitHub|Bitbucket} repository you are attempting to sync?" message when trying to link our company GitHub account to JIRA.
I am the administrator. Private and public repositories are listed. The public repositories can be linked without a problem.
Roustem Karimov
June 18, 2013
Thank you Immanuel.
I am the administrator and I was logged into GitHub. Unfortunately, there is no separate login for organization in GitHub. While I was able to see both my and company repositories, linking only worked for my own repositories not for company repositories.
I was able to fix that later by clicking "Re-generate OAuth Access Token" option:
Menu
Immanuel Siagian
June 18, 2013
Hi Roustem,
There is an existing article which shows similar exception as yours: https://confluence.atlassian.com/display/JIRAKB/Unable+to+Connect+to+a+Private+Repository+using+the+DVCS+Plugin
Basically, you will also need to login to Github (as the administrator to the repo) on the same browser as JIRA. Can you confirm whether you have logged in?
