we have following Errors:
Beim Starten von Jira sind folgende Fehler aufgetreten. Sie müssen alle Fehler beheben, bevor Sie Jira erneut starten können.
We couldn't start the following plugins:
MySQL 5.5.5-10.1.38-MariaDB-0ubuntu0.18.04.1 is not supported. You should migrate to a supported database version.
Supported versions are: 5.7, 5.6
Your mysql database is currently using an unsupported collation: utf8_general_ci. You should change this to a supported collation:
Review our documentation for more information on supported collations.
What should we do?
according to the error message you provided, you have several issues.
You should start from upgrading your MySQL database to a newer version and then see what issues still remain, if any.
