Problem to solve via automation rule
Vivek Challa January 12, 2024
Problem to solve via automation rule :
Hierarchy of the Issuetypes :
Epic-> Story->Subtask
Whenever the StoryPoint field at Sub-Task level is updated (Addition/deletion/change), StoryPoints of all subtasks under a story should get added and updated to Story level.
Story points of all stories should get added and updated to Epic Level.
StoryPoints should be updated only at Sub-Task level.
Bill Sheboy
January 12, 2024
Hi @Vivek Challa
What have you tried thus far to solve this problem?
If you have created rules and are running into challenges, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected.  Those will provide context for the community to offer ideas.  Thanks!
If you have not yet created a rule, please note using automation successfully requires learning and experimentation.  When one just uses rules provided by others without understanding them, they will not be able to maintain them when problems occur.
I recommend trying to create your rules to solve the problem first, and ask for help if needed.  To get you started on creating your rule, please refer to these documentation and example sources:
Nicolas Rigaill
FREE
