Link formatted as:
[link text|/////server_name/folder/folder/folder/file.extension]
Works in IE9
Error message from javascript console is:
"2 Not allowed to load local resource: file://server/folder/folder/folder/file.extension"
LocalLinks extension for Chrome browser can be found here:
https://chrome.google.com/webstore/detail/jllpkdkcdjndhggodimiphkghogcpida?hc=search&hcp=main
I came across a similar problem with firefox. The reason is that Firefox does not allow users to access remote share driver, and this is an internal setting that users cannot change except installing plugins. I believe it is the same situation you met. you can search for plugins on google or add a note to ask users download with IE.
