I created a project but there was a bugg at the time of creation, since I can not use or delete it.
Error message when deleting :
Confirm that you want to delete this project and all its issues, components and versions.
WARNING : This operation cannot be undone. If you wish to save the project data, it is recommended that you back it up first.
I have an AITT.zip file in the following directory :
/var/atlassian/application-data/jira/export
How to remove or run this project ?
regards,
@Quentin Bellégo [Valiantys], Reindexing did not solve the problem.
Thank you @Quentin Bellégo [Valiantys], I will try tonight, not to slow production.
Maybe a re-indexation could solve your problem ?
