Problem when working Test Session
jennyjin
October 17, 2014
I'm using Capture 2.8 on a project. A test session is created, however, several key features are not working, it prevents my from using test session in my project, the critical errors I'm seeing
  1. Browser test session. None of test session is displayed with filtering options sets to all
  2. "Invite" and "More Actions" button on view session page doesn't work, nothing shows up with clicking these two buttons, all buttons are directed to https://jira.xxxx/ViewSession.jspa?testSessionId=xxxxCapture2.JPG
Ignat
October 20, 2014
Hi Jenny Jin,
I've quickly checked and see no issues with test sessions. Could you tell what browser are you using, I see no issues in Chrome and Internet Explorer with JIRA 6.3.1 and JIRA Capture 2.8.4. What happens when you click 'Reset Filters'?
In order to get a reply faster, it's better to contact Atlassian Support directly, while JIRA Capture issue tracker is the best for reporting issues.
Thanks!
Ignat.
