I developed a plugin of SelectList CF type. During "Resovle" transition i added this custom field as *required* using JIRA Suit Utilities plugin. There after my custom field and the validator provided by JIRA Suit utility lived happily together.
But recently i had to delete my custom filed. After deleting my custom field I am not able to delete the Validator :-(.
Error on Resolve Transition:
"An unknown exception occured executing Validator com.googlecode.jsu.workflow.validator.FieldsRequiredValidator@10499c5: root cause: The second parameter is null."
The following text is displayed under validator:
Type: class
Class: com.googlecode.jsu.workflow.validator.FieldsRequiredValidator
Arguments:
hidFieldsList = customfield_10025@@customfield_10373@@customfield_10177@@customfield_10374@@customfield_10560@@
I don't see the delete option when i create a "draft" of WorkFlow to remove this validator. My deleted custom field ID is customfield_10560.
I followed the amendment of dataBase described here. But no luck.. How can i delete this custom field value from the validators list? or how can i delete the whole validator so that i can re-add the required field again?
Any thouthgs?
Cheers!
You can do this quickly by SQL operator, which deletes occurrences of "@@customfield_10560" from workflow descriptor. Of course, it must be done while Jira is stopped.
Next steps are valid for MySQL, in other databases queries can differ. See your database's manual for REPLACE() string function.
1. Figure out an ID of buggy workflow by SQL query
use jira;
select ID, workflowname from jiraworkflows;
2. Run SQL query for deleting occurrences of "@@customfield_10560"
update jiraworkflows set DESCRIPTOR = REPLACE(DESCRIPTOR, "@@customfield_10560", "") where ID = INSERT_YOUR_WF_ID;
Start Jira instance.
Denis Yaparov
Thanks Denis, Let me try this option on DB and share my feedback.
Denis I am not able to upload a saved image on my PC. The image you uploaded is ffrom web i guess. How to upload an image that i have on my pc?
You can use one of picture hosting services.
Anyway, you should register this additional question as separate one in main questions list.
Sure will do :-) Thanks for your quick help on REPLACE command.. The fix works with very minimal effort :-D
Cheers!
(JIRA 7)
Had the same bug, and for me the following workaround worked:
exported the workflow XML and found the "offensive" validator. Then edited the workflow and deleted the 'suspicious' jirasuite utilities validator (it looks very normal from the regular workflow editor) and then defined the same one again (using only existing customfields).
Sounds like a bug. You could export the workflow as XML, edit the XML to remove this validator (just search for the classname), then create a new workflow based on this XML.
Yes! This is a bug. Thanks Jamie, I did XML import but the problem with this is, After i associate new workflow to a Issue Type i need to change the workflow Scheme for all the projects and this will take more than 48 hours for me to do through UI :-(. Can i change the workflow scheme for all the projects on the database directly?
Another question is that, I have a custom select CF type, I have added values Yes and No for this custom field, but when i go to "Edit Defaults" for this custom field it is not able to populate any values here. Any thoughts? I only see "Set Default" and "Cancle" without field name and values select list on this screen.
Yes, you can do bulk change WF Scheme by SQL query. There is table "nodeassociation" in Jira database.
Stop Jira instance.
MySQL:
1. Explore it by query
use jira;
select * from nodeassociation limit 100;
2. Figure out an old and a new WF Scheme's IDs
select ID, NAME from workflowscheme;
3. Run substitution SQL query
update nodeassociation set SINK_NODE_ID = INSERT_NEW_WFS_ID where SINK_NODE_ID = INSERT_OLD_WFS_ID and SINK_NODE_ENTITY = 'WorkflowScheme';
Denis Yaparov
