Problem with Jira 5.2.6 and html encoding in comments?
Bryan Karsh
July 2, 2013
I noticed that if I add a comment like so:
<value name="search.google.url">http://www.google.cl/search?</value>
It ends up like so:
Any idea what is going on, or how I can fix? Thanks.
Justin Alex Paramanandan
July 2, 2013
Have you tried to use the {noformat} macro within the comments? Something like:
{noformat}
{noformat}
This will ensure that the HTML format you've entered will be retained as-is.
Bryan Karsh
July 11, 2013
Thanks. I switched renderer to Wiki style, and that solved my issues.
Bryan Karsh
July 2, 2013
by the way -- if I go to the edit screen for the comment, I see the correct xml --- so it appears correctly in some situations.
