Hi
Im trying to set up JIRA and confluence on a windows server with ssl.
I manage to install both and its working.
Now im trying to get it to work with SSL.
I followed the tutorial and created a certificate and a keystore.
I added this to my web.xml
<security-constraint> <web-resource-collection> <web-resource-name>Restricted URLs</web-resource-name> <url-pattern>/</url-pattern> </web-resource-collection> <user-data-constraint> <transport-guarantee>CONFIDENTIAL</transport-guarantee> </user-data-constraint> </security-constraint>
My JIRA server.xml looks like this
<?xml version="1.0" encoding="UTF-8"?> <Server port="8005" shutdown="SHUTDOWN"> <Listener className="org.apache.catalina.startup.VersionLoggerListener"/> <Listener SSLEngine="on" className="org.apache.catalina.core.AprLifecycleListener"/> <!-- Prevent memory leaks due to use of particular java/javax APIs--> <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener"/> <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/> <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener"/> --> <Service name="Catalina"> <Connector SSLEnabled="true" acceptCount="100" clientAuth="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" keyAlias="alias" keystoreFile="PATH TO JKS" keystorePass="PASSWORD" keystoreType="JKS" maxHttpHeaderSize="8192" maxSpareThreads="75" maxThreads="150" minSpareThreads="25" port="8443" protocol="org.apache.coyote.http11.Http11Protocol" scheme="https" secure="true" sslProtocol="TLS" useBodyEncodingForURI="true"/> <Engine defaultHost="localhost" name="Catalina"> <Host appBase="webapps" autoDeploy="true" name="localhost" unpackWARs="true"> <Context docBase="${catalina.home}/atlassian-jira" path="/jira" reloadable="false" useHttpOnly="true"> <Resource auth="Container" factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60" name="UserTransaction" type="javax.transaction.UserTransaction"/> <Manager pathname=""/> </Context> </Host> <Valve className="org.apache.catalina.valves.AccessLogValve" pattern="%a %{jira.request.id}r %{jira.request.username}r %t &quot;%m %U%q %H&quot; %s %b %D &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; &quot;%{jira.request.assession.id}r&quot;"/> </Engine> <Connector acceptCount="100" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxSpareThreads="75" maxThreads="150" minSpareThreads="25" port="8009" protocol="HTTP/1.1" redirectPort="8443" useBodyEncodingForURI="true"/> </Service> </Server>
my confluence server.xml looks like this'
<Server port="8000" shutdown="SHUTDOWN" debug="0"> <Service name="Tomcat-Standalone"> <Connector port="8090" connectionTimeout="20000" redirectPort="8443" maxThreads="200" minSpareThreads="10" enableLookups="false" acceptCount="10" debug="0" URIEncoding="UTF-8" protocol="org.apache.coyote.http11.Http11NioProtocol" /> <Engine name="Standalone" defaultHost="localhost" debug="0"> <Host name="localhost" debug="0" appBase="webapps" unpackWARs="true" autoDeploy="false"> <Context path="/confluence" docBase="../confluence" debug="0" reloadable="false" useHttpOnly="true"> <!-- Logger is deprecated in Tomcat 5.5. Logging configuration for Confluence is specified in confluence/WEB-INF/classes/log4j.properties --> <Manager pathname="" /> <Valve className="org.apache.catalina.valves.StuckThreadDetectionValve" threshold="60" /> </Context> </Host> </Engine> <Connector port="8010" redirectPort="8443" enableLookups="false" protocol="AJP/1.3" URIEncoding="UTF-8"/> <Connector acceptCount="100" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" port="8080" protocol="HTTP/1.1" redirectPort="8090" useBodyEncodingForURI="true"/> <Connector port="8443" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" protocol="org.apache.coyote.http11.Http11NioProtocol" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" clientAuth="false" sslProtocols="TLSv1,TLSv1.1,TLSv1.2" sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2" SSLEnabled="true" URIEncoding="UTF-8" keyAlias="alias" keystoreFile="PATH TO JKS" keystorePass="PASSWORD" keystoreType="JKS"/> <!-- --> </Service> </Server>
Hope someone can help
Regards
jakob
The problem is that it dont work
I got different kind of errors, and was not able to set it up.
JIRA is causing a 502, and confluence is not being redirected to https
Well what's the problem?
