Today we start getting an error from Tempo gadgets:
"This gadget cannot be displayed on your dashboard. This could be due to a licensing problem or an application error. If you need this gadget, contact your administrator for assistance. Otherwise, you can remove it from your dashboard."
Log says:
2020-06-11 19:06:52,835+0300 ajp-nio-8009-exec-112 WARN user 1146x6056220x1 uajfji 123.456.78.90 /secure/Dashboard.jspa [c.a.g.renderer.internal.GadgetSpecFactoryImpl] Error occurred while retrieving gadget spec for rest/gadgets/1.0/g/is.origo.jira.tempo-plugin:tempo-timesheet-charts/gadgets/tempo-timesheet-charts-gadget.xml
Why did it happen and what we can do with that?
Thank you.
the thread that you refer to is probably related to another (older) problem.
We have released a hotfix for the gadget problem in late May 2020. So make sure you are on newer version then this. See the release notes below:
The hotfix has also been implemented in the most recent versions of Tempo 8 and Tempo 9.
Regards
