Problem with Thread Limit on OSX
Jacek Skrobisz February 25, 2018
I install JIRA server on OSX High Sierra, and got warning:
max user process limit is 1418.
Try find something in google, but no luck.
How to fix that?
I try change with ulimit -u, but that not change anything.
Help.
Metin _savignano software solutions_
Turn on performance mode for macOS Server using
sudo nvram boot-args="serverperfmode=1 $(nvram boot-args 2>/dev/null | cut -f 2-)"
and reboot.
somethingblue
February 26, 2018
Hi Jacek,
Take a look at the blog post El Capitan ulimit shenanigans where he explains this is due to crsutil or SIP which was introduce a couple years back.  He provides a way to workaround disabling SIP:
As it turns out this one can work even without disabling csr on osx, the way to do it: Change ownership of the above files to root:wheel and it reload them with:
# sudo launchctl load -w /Library/LaunchDaemons/limit.maxfiles.plist
# sudo launchctl load -w /Library/LaunchDaemons/limit.maxproc.plist
After reload it should work.
Hopefully this helps.
Branden
