×Hi everybody,
we use JIRA in version 6.3.12 (Windows 64 Bit Installer) standalone on our system.
Now we have installed a second instance of JIRA on the same Server.
The second instance starts, but we have problems with Tomcat.
We have read from the Atlassian website:
Not deploying multiple instances using a Single Tomcat Application Container
https://confluence.atlassian.com/display/JIRA/Running+multiple+instances+of+JIRA+on+one+machine
Is there a specific configuration we need to do for tomcat ?
Best Regards,
Sven & Andrei / Peter
Hello Sven,
I looked to my server.xml in JIRA Tomcat and think that you could need to adjust one more port not outlined in article you linked in the question. Here is snipped of the XML with ports highlighted by "==".
<Server port="==8005==" shutdown="SHUTDOWN"> ... <Service name="Catalina"> ... <Connector port="==8080==" protocol="HTTP/1.1" connectionTimeout="20000" redirectPort="8443" ... <!-- Define an AJP 1.3 Connector on port 8009 --> <Connector port="==8009==" protocol="AJP/1.3" redirectPort="8443" />
You can use 8006, 8081 and 8010. Just make sure that they are not used: http://stackoverflow.com/questions/273159/how-to-determine-if-a-port-is-open-on-a-windows-server
Hi Sven and Peter,
What's the error message you are getting? I can't seem to see it in the attached screenshot.
Anyway, if you want to install multiple instances of Stand Alone JIRA on a server you will need to change at least:
Best regards,
Peter
@all
THX for Support.
It works now perfectly.
Best Regards,
Sven & Peter
@Volodymyr Krupach
Now we have made screens from our server.xml.
THX for helping
Hi Sven, Maybe this article can help you out: http://stackoverflow.com/questions/16110528/tomcat-multiple-instances-simultaneously ? Best regards, Peter
Hi again and thank you for the support so far, we managed to get it up and running but we stumbled now again on a different issue. As we have two instances on the same server, we can only run one instance at a time, they can't run both at the same time. Is this normal to happen or are we doing something wrong ?
Hi Andrei! They should run as long as they are on different ports. Please check the ports as outlined in my previous answer.
Peter and Sven, It seems that your JIRA instance is locked, could you please follow the instructions here: https://confluence.atlassian.com/pages/viewpage.action?pageId=223220062
Hello Volodymyr and Peter,
Thank you for the quick reply, we did use different ports and also created another database and of course we used different instalation folders. The only thing we didn't know how to do was the configuration for Tomcat to not use the same container, we are noobs on this part and we need some guidance.
The issue is that the second instance is not launching, the web page is not starting.
Should we get you some log files ? And which ones ?
Peter
Could you take a look in the atlassian-jira.log file in the home-dir/logs directory of your second instance? If you have installed a second standalone the container shouldn't be an issue. Best regards, Peter
Hi Sven!
You need separate Tomcat and need to adjust ports as described in the article you linked.
