Problem with attachment
Michael Louie Ancheta October 24, 2013
Hi Support,
I am having a trouble when attaching the screenshot using JIRA. It goes to the Oracle site. I already installed the latest version of the Java but still pointing to Oracle. I tried all the web browser but still no good.
Can you please assist in checking this issue. Please find the screenshot below.
Thanks in advance.
Michael A.
Hyperwallet Systems Inc.
Michael Louie Ancheta October 25, 2013
Hi JIRA Support,
Unfortunately the plug in you provided is not working on JIRA version 4.4.3 do you have the available plug in for that version ? We are using version 4.4.3
Michael A.
Jeremy Largman
October 24, 2013
A workaround - although an extra step - is to take your screenshot locally on your system (some tips for that are here in the main attaching a screenshot doc), then attach it using the regular attachment functionality.
There's also a plugin that doesn't depend on Java, if you have access to your administration and are willing to enable it.
As for solving the problem locally, there's a knowledge base article that might help.
Beyond that, I'm not sure: there's likely a different factor involved -- I'd guess some kind of security in place -- given your comment that you already installed Java and it's not working on any browser. Let me know what you did to install Java.
Hi JIRA Support,
Michael A.
