Problem with connecting jira to active directory
Marcin Rytt September 1, 2013
just like in a topic, i have a problem / i don't know how cas i connect jira to AD. I read every tuturail and still have the same poroblem: Test retrieve user : Failed
This is my AD tree:
ABC.COM
--AA
---Workers
---Branch Office A
---Branch Office B
---Branch Office C
Could someone tell me how can i must set this ad ou's in jira ?
it dosn't work, i must do some wrong configuration.
my_ad_tree Could u tell in the begginig what i must choose and what set to connect jira with my ad.
In the beggining i must choole Active Directory, LDAP or what ? ;/
Teck-En
September 4, 2013
Which LDAP server you're using? Microsoft AD, openldap, or etc.? For the differences of the selection:
Microsoft Active Directory - Synchronization type of Directory
LDAP - similar with above except you get to connect with other kind of AD such as OpenLdap.
Internal with LDAP authentication - user created in JIRA database but the password will authenticate with LDAP server
Select the correct directory, and get the connection works. Leave the other settings remain default(unless your AD are high customized) while make sure the connection works, admin user being able to retrieve.
Zul NS [Atlassian]
September 4, 2013
Since you are using AD, then you can use Microsoft Active Directory configuration. If you are good in Active Directory, perhaps you can use 'dsquery'
Example: dsquery user -name administrator
Where administrator is the user that you are trying to sync. From there, it will return the FQDN for the particular user to help you configure Additional User DN when needed.
When you say its not working, what is the error? Only failed to retrieve user? Does that means the connection works?
Teck-En
September 1, 2013
Is the Workers ou within the AA ou? If that's the case, I suppose you should use ou=Workers,ou=AA for Additional User DN
If that's still not working, empty the field and try the configuration again.
for ex.
Base DN: dc=ABC,dc=COM
Additional User DN: ou=Workers ( or i tried Branch Office A )
Additional Group DN: ou=AA ( or i tried Workers )
i tried this configuration and didn't work
Teck-En
September 1, 2013
Few questions here:
  1. Where's the base dn point to?
  2. Did you specify the Additional User DN there? If any, can you provide the example of the value you input?
  3. Is the user searchable with the user object filter Under User Schema Settings
