Problem with creating subtasks
Kateryna Mekhdiieva July 2, 2024
Hello! I can not create a subtask within a task! After your updates probably something happened, what should I do?? I`m blocked!
Mohammed Aamer Khan
July 2, 2024
Hi @Kateryna Mekhdiieva
Can you please help us with Hosting type and the error so that we can help you accordingly.
I see that there is some updates, new view. I see + button inside the task, see the +create subtask button, I can even click on it but nothing happens.
Mohammed Aamer Khan
July 2, 2024
Can you also check if Subtasks creation is enabled or disabled by any chance. refer below link on how to do it
https://support.atlassian.com/jira-cloud-administration/docs/configure-sub-tasks/
I followed these steps: Select > Issues. Under ISSUE TYPES, select Sub-tasks. But then I can`t click on this. it`s not clickable
Mohammed Aamer Khan
July 2, 2024
Can you share screen shot if possible?
Screenshot 2024-07-02 114226.pngI click on this and nothing happens
Mohammed Aamer Khan
July 2, 2024
Is it happening with all users or just at your end?
If it is just at your end try to remove browser cache and try again
with all users
Fazila Ashraf
welcome to community!
Do you have subtask type added in the project's "issue type scheme"?
Yes, everything was fine until new JIRA  updates.
Like Jonas Madsen likes this
